Help needed with photos
Gazzam
Post by Gazzam » Tue Jan 21, 2025 4:14 am
Hello all,
I'm doing a resto on my 1965 Tiger. And at the moment I’m stuck.
I’m looking for photos of the rear part of the front inner wing. Or guard.
The area behind the front wheel.
Mine has had rust repairs in this area, and there are patches over patches.
I’m finding it difficult to work out how the sheet metal is supposed to go together.
Thanks in anticipation.
Garry.
Re: Help needed with photos
Post by garyf » Tue Jan 21, 2025 1:19 pm
This is a picture I took when I was rust proofing my old tiger, I believe this is how they should look, it's not that clear but I hope it helps.
3. Bulkhead & Sill.jpg (52.52 KiB) Viewed 287159 times
Gazzam
Post by Gazzam » Tue Jan 21, 2025 6:19 pm
Thanks Gary,
That’s the area. Mine has been patched and I don’t know how it’s meant to be attached to the sill.
Garry
Post by garyf » Fri Jan 24, 2025 2:53 pm
The recessed section on the arch were it meets the sill is correct I believe.
I drilled some holes in the arch at low level so I could pump rustproofing fluid into the two Sill box sections.
