My temp gauge is reading higher than true temp. Garage say it has 7.1v going in to it instead of 4.4v.
Any ideas how to correct or do you know of a company that can advise the correct resistor to reduce the voltage or can correct it for me?
Temp gauge voltage problem
check that your voltage regulator is properly grounded under the dash. this is supposed to reduce the voltage going to the gauges to about 10V. its a mechanical device (works by heating a strip which then bends and breaks the circuit, then cools and bends back at high frequency) and they do fail.
i have a replacement solid state device made out of regular electronics by some tiger guy in the US.
i can recommend using mechanical water temp and oil pressure gauges which are a lot more reliable and add to your confidence a lot. in my case its only the fuel gauge which needs the regulator and that thing is far from accurate and responsive at the best of times
there is at least one article covering this on the tigersunited website:
www [dot] tigersunited [dot] com/techtips/cb-reg/reg.asp
