Door seals and channels
Brad1380 wrote:my locks is missing that part?
That little buckle twists 90 degrees and fits over the short piece with a rod that's about 3 inches long and connects between the lever operated by the door key and then operates the locking mechanism of the door lock unit. It is needed to connect the door lock together. Looks as if it is connected in place by a small circlip assembly, and spring. Easily fitted if you can find it.
I did manage a few more hours on the Tiger today, but in the week did manage to clean, paint and waxoyl inside the door;
Pleased with the panels being truly rust free, out of interest the Tiger came from the USA in the late eighties.
Today though, I wasn't happy with the 'lethargic' movement of the door lock assembly as it wasn't catching the lock on closing the door as I would have liked. So it came out again and to get 50 years of hard grease crud removed, together with the galvanised film I used Hydrochloric Acid to clean it thoroughly. Now the door lock has lots of sticky lube attached and the door lock now works as it should. Amazaing what 50 years of crud does to the operation of the lock
Plenty of white grease in the window channel runner;
With the rear lower channel in first, and the window winder mechanism loosely fitted and greased the window easily fitted onto the runners today.
Front lower channel needs yet to be fitted, hopefully will have more time next weekend.
Was also advised before fitting the window to fit outer upper window outer weather seal in place, as it easier to get to those 'bastard' clips with the window out.
My daughter's 16th birthday party got in the way today
Tomaselli in APRIL 2015 wrote:UPDATE;
DO NOT USE ANY ACID MATERIAL TO STRIP LOCKING MECHANISM AS IT RUINS THE INTERNAL COMPONENTS!!!!!!!!!!
Patio cleaner from the local builder's merchants
Care though, as it also takes off the galvanised coating. I'll just make sure I keep the mechanism lubed up. Using that sticky Wurth penetrating oil.
Tomaselli APRIL in 2015 wrote:UPDATE;
A few spare hours today so carried on with the passenger door weather seals.
Pretty much everything was in place now for me to finish the job.
Cleaned the windows as 50 odd years of grime had accumulated, and wanted then clean so I get the channels properly lubed up
Front lower window channel I had already lined up with the quarterlight fitting. The channel has to be a continuous seating for the window. With knowing that it all in place, a bit of red oxide to keep the weather off for the next 50 years.
Very pleased with the final fitting of the external glass door weatherseal..
Quarterlight unit next, that slotted in nicely and pre-measuring of external seal made final fitting a breeze
Quarterlight had window channel already in place and 'butted' up nicely to the lower front window channel.
I was surprised by how much one can adjust all the window channels and window regulators. A combination of ensuring the channels are tight in the door, runs straight and not overly tight for the window winder mechanism.
One adjustment was the height and stop of the window, it was always a bit too high. So an opportunity to fine tune...
Everything lubed up and greased as it should be. Was bone dry before!!
Final fettling;
Inner weatherstrip, chrome side up
Final result, very pleased!
Final pic. Old weatherstrp against the correct new one. The old one was never going to fit correctly and do the job, and finally completed after 16 years waiting
Now to do the other side
Thanks for everyone's help along the way
Final fettling;
Door channels and seals
Nice work there Tony,,and a good article well illustrated with clear pics.
Always good for owners to see what is involved in doing these jobs if they attempt to do them themselves :D
Thought I'd better 'crack on' with the other door before the Tiger season is soon upon us.
Rather than bombard you fine folk with loads of images, of the same, thought I would treat you all to my selfie
Cleaning inside the door, not an easy task, but good to see only light surface rust and nothing major. Good old American import with no real rust, very lucky.
Anyway, I need a few bits if anybody has any spare.
A set of the these spacers;
And, a set of these screws with large panheads, there are four of them that secure the winder mechanism to the door frame. I need two, of the longer type;
Any help would be greatly appreciated.
