Wheel stud thread size
Posted: Tue Aug 30, 2011 8:04 pm
by thdxb08
Hi all, it's time to replace the rusting wheel nuts on my Tiger MK1.
Can anyone help me with the thread size on the wheel studs.
Also should I use Stainless steel or Aluminium wheel nuts to be used on Minilite wheels.
And my last question does anyone know of a good UK supplier for wheel nuts.
Derek
Posted: Wed Aug 31, 2011 6:57 am
If your rims are Minilites I would contact them first. Then you know you are getting the correct nuts for the wheels.
Re: Wheel stud thread size
Posted: Wed Aug 31, 2011 8:19 am
thdxb08 wrote:Hi all, it's time to replace the rusting wheel nuts on my Tiger MK1.
Derek
Hi Derek,
I believe the thread size is 7/16, but not sure of the thread pitch. I fairly sure they are a standard thread for wheel nuts.
Posted: Wed Aug 31, 2011 9:49 am
Derek,
Stud size is 7/16 inch UNF and the standard 4 stud hole Tiger wheel has a 108mm PCD.
This is the bloke to advise you on all things related to matching wheel nuts, whether steel or alloy:
http://www.mistertee.co.uk/6.html
Tel: 0208 680 2613
Posted: Wed Aug 31, 2011 5:02 pm
by thdxb08
Many thanks for all your replies, just what I needed.
Derek
Posted: Wed Aug 31, 2011 5:54 pm
by tigerguy2
Although this is not part of an answer to your question, just thought I would add a general info point. It is old information for many but not everyone seems to know it.
Should you ever be running stock wheels again for a concours event, or perhaps as a spare tire, keep in mind the factory lug nuts are somewhat unusual by today's standards. They, and the corresponding wheel hole, have a 60 degree taper. Most nuts and wheels today, except for racing wheels, have a 30 degree taper. If the taper of the nut and the wheel do not match, the wheel and nut will not seat and torque properly. The result will be ruined stock wheel holes and a wheel that likely will come off while driving.
Cheers, Gene
Posted: Wed Aug 31, 2011 11:10 pm
I would say that is fairly important point to bring up Gene. I for one did not know that and important to me because my spare is a stock rim. I do however carry what I assume are the correct wheel nuts for the stock spare.
Thanks, Robin.
Posted: Wed Aug 31, 2011 11:43 pm
Gene made a good point about the different taper angles. This is something that I discovered when talking to Mister Tee (see earlier post).
Another very important safety point is to ensure that all repainted wheels have had all paint removed from the taper surfaces.
Failure to do this will often result in self-loosening wheel nuts and possible wheel loss.
Please don't think that it just a case of wheel imbalance. One or more wheels are probably about to fall off!!
Posted: Thu Sep 01, 2011 5:06 am
by tigerguy2
You are quite welcome. Glad I could make a contribution. I also carry the stock wheel and factory nuts as my spare, so this is something somewhat top of mind with me.
Cheers, Gene
Posted: Thu Sep 01, 2011 9:04 am
Note that if wheel spacers or non-standard wheels are used, it is vital to ensure that every wheel nut is threaded on to the stud by a MINIMUM of 1.5 times the stud diameter.
In this case 1.5 x 7/16 = 21/32 inch (0.65625 inch).
wheel studs
Posted: Sun Dec 11, 2011 11:34 am
by TXJ7
I have a spare set of extra long wheel studs if anyone is interested
