Failing coil
Posted: Sun Apr 08, 2012 12:40 am
by tigerman7347
Right, I have a unilite dizzy , unilite ballast resistor and a unilite coil. So why is the coil failing ? Wiring is ok. Any suggestions?
Thanks Rob
Posted: Sun Apr 08, 2012 1:33 am
Hi Rob,
How old is the coil? It sounds like it has developed an internal fault. You could try replacing the ballast resistor or re-terminate the connections to the resistor. Is it the correct coil for a ballast style ignition system?
Failing coil
Posted: Sun Apr 08, 2012 9:20 am
by tigerman7347
Hi, coil is less than 2 years old,probably only covered 4000 miles.
