engine earth strap
Posted: Mon May 06, 2013 11:38 am
by ksherlock
The engine earth strap on my car is attached on one end to the front bolt of the L/H exhaust manifold and on the other end to one of the bolts on the lower end of the left hand bracing rod . Is this the correct location for the earth strap ?
Posted: Mon May 06, 2013 12:12 pm
This earth strap is usually connected from a point on the nearside chassis to a bolt on the engine plate/block plate or possibly to a gearbox/bellhousing bolt.
engine earth strap
Posted: Mon May 06, 2013 3:38 pm
by redbaron
The earth strap is bolted to one of the redundent Alpine gearbox crossmember bolts,5/16ths unf, and the other end is located on the clutch slave cyl mtg bolts,for the slave cyl.
