Page 1 of 2
Engine Rebuild
Posted: Mon Aug 05, 2013 6:38 pm
Does anyone know what the ball park figure is for an engine rebuild on a 260ci engineand places that do them?
Thanks.
Posted: Tue Aug 06, 2013 8:19 pm
No one?
Ok, has anyone had a SBF rebuilt and how much did it cost minus parts?
Posted: Tue Aug 06, 2013 8:55 pm
dean did my 289 as for price depends on what you need.and if you want a warranty lol .mine was honed rather than rebored .so save on pistons ect .had 30lb oil pressure before and 7 broken rings .now 55lb.
dave herningand john sleath also
Posted: Wed Aug 07, 2013 11:20 am
Thankyou Gary.
The thing is, I've removed the cylinder heads and found the tops of the pistons and the cylinder head are covered in burnt on black crap.
It could be a bad case of carbon deposit or it could be burnt oil.
There seems to be a lot of it too but as I am very inexperienced with engines, I dont really know.
I intended to replace the gaskets on the engine and unlead the heads and pretty much leave it at that but then this has come along and I dont know what to do.
I may contact Dave Herning and see what he thinks as he has been extremely helpful in the past or I may just put a cover over it and forget about it for a while.
Posted: Thu Aug 08, 2013 4:11 am
Martin,
can you post a picture of the block & heads.
Posted: Thu Aug 08, 2013 4:35 pm
Cylinder head
Pistons
Dont get hung up on the oil residue.
I took the heads off some time ago and because I knew it was going to sit for a while I (rightly or wrongly) put a tiny amount of oil in each pot.
Do they look like original pistons?
Posted: Thu Aug 08, 2013 6:28 pm
by Ash
Martin, clean up the top of a piston to see if there is anything stamped onto it? I maybe wrong but I think the originals had STD on them. If they have been changed its usually because the bores needed enlarging and the pistons will have the oversize amount stamped on them.
I stripped my last engine down but left the crank assembly in situe. I got my local engine shop to hone the bores and put in new rings and bearings, also to clean out the block and pistons etc. Didnt charge a lot :shock:
Posted: Thu Aug 08, 2013 7:14 pm
Cleaned 2 pistons. No markings at all.
Posted: Fri Aug 09, 2013 11:17 am
How much of a build up is there at the top of each bore? If it was me i'd drop a couple of valves to look at the seats & stems & also take a piston out to check the bores & rings.
Posted: Fri Aug 09, 2013 12:38 pm
by Ash
Martin
It appears I was giving you duff info as just checked my 260 pistons and no markings either :oops: Must have been confused with something else I took to pieces!
Sorry dude :cry:
Posted: Fri Aug 09, 2013 8:23 pm
Martin.
How was it running before you pulled the car apart. Oil pressure etc.
Posted: Fri Aug 09, 2013 8:31 pm
It was a few years ago but as I remember it was running nice and had good pressure. Can't remember what it was exactly though.
Posted: Sat Aug 10, 2013 7:32 am
garyv8tiger wrote:dean did my 289 as for price depends on what you need.and if you want a warranty lol .mine was honed rather than rebored .so save on pistons ect .had 30lb oil pressure before and 7 broken rings .now 55lb.
When i google Dave Herning Motorsport, it says he's no longer in business?
http://www.yasni.co.uk/ext.php?url=http ... &showads=1
Engine Rebuild
Posted: Sat Aug 10, 2013 10:54 am
by redbaron
Hi Martin,
the pics of the pistons show standard pistons/bore.
Carbon on valves and heads,normal for an original engine.
Yes I am still in business,phone numbers in front of your Cats Wiskers Magazine
David
Posted: Sat Aug 10, 2013 8:09 pm
looks like it just wants a de coke.as old leaded cars uesd to .the engines are pretty bombproof .unless you buy a brand new one and it stops after 1500 easy miles
