Track days exhaust
Track days exhaust
Any ideas/experience of getting exhaust noise down to 105db for up coming track day? Running twin 2 1/2" pipes with "cherry bombs" Suspect well over 105 at present!
Whilst I'm not saying you should do this now. When I used to rally back in the 70/80's if a car failed scrutineering due to a noisy exhaust we used to shove brillo pads up the tailpipe.
Marshals had to be careful on the event as the pads often shot out of the exhaust pipe when the car passed.
Ahh those were the days - no Health and Safety back then.
Lou.
Lou.
I did wonder about these
https://www.merlinmotorsport.co.uk/p/me ... -ex-muff-4
Look easy to fit, but not sure if reduction would be enough.
H, Sunny 65
Plenty of free APP's for smart phones, out there to measure db's.
I have a couple on my phone, not measured my Tiger noise yet, but may fire it up to over the weekend to see what noise it makes.
Wire wool in a coke can with holes over end and j/clip to end of pipes works for noise reduction. .[that method a bit more you Bob, than the fancy pipes you saw]
Harry
Harry
Its measured 1meter away and at 45degrees vertical from the tailpipe.
revs depend on the tester/circuit sometimes they ask for the max revs and then work out 2/3 of that or they ask for 4500.
Jay
Jay
According to the MSA regulations:
“the sound test shall be conducted as set out within these regulations with the engine running at 3/4 maximum speed, the sound level meter at a height of 0.5 metres above the ground (± 0.1 metre) located at 45° to and 0.5 metres distant from the exhaust”.
That way the scruitineer doesn’t kop a mouthful of Brillo Pad!
Incidentally if you have a Mk1Tiger ¾ maximum is around 3500rpm.
Oh and don’t rely on one of those phone apps as they usually max out at 105db.
Lou.
Lou.
Just swap the rev counter for a 4-cylinder one. Halves the revs (oh no it doubles doesnt it? Maybe a 12 cyl one then)
I could easily recal a four to make it read much lower
Re wire wool, it is so fine it might catch fire. I bought some stainless steel pan scourers at Aldi that could be be worth a try?
