In line strainer available in the UK ?
Posted: Tue Jun 17, 2014 7:45 am
by Dom
Hi
I am contemplating an Ali rad, however ( being a heating engineer ) I don't want it to block up with ferrous material from the block ( even after flushing )
2 companies do in line filters in the states, can you get them over here ?
Dom
Posted: Tue Jun 17, 2014 11:27 am
by le tigre
I use a TEFBA filter on both my Tiger and Healey to protect the rads. It is made in Australia but you can buy it from ebay, just do a search.Very efficient fast delivery. Available in different pipe diameters. Highly recommended. Stainless steel mesh you remove and clean. Frightening when you see how much stuff is removed. From memory about £25
Andy
Posted: Tue Jun 17, 2014 9:59 pm
Funnily enough, I fitted the Gano type about 4 years ago (I like me gadgets) and wasn't sure if it was worth it, and only this last weekend I checked it over as I was changing hoses/radiator.
Bearing in mind I had a new engine block and alloy rad when I originally fitted the filter I thought I would be fine, but it did indeed catch some muck. Lord knows how it gets in the system. Looked mainly like gasket material.
Excuse the poor phone camera pics;
Cleans easy enough;
Originally ordered from the US CATS website. Don't think I've seen them for sale in the UK. Be handy if one of the Tiger specialists sold them 8)
Ali rad
Posted: Tue Jun 17, 2014 10:36 pm
by tigerman7347
I have been told on good authority that when fitting an Aluminium Radiator , rubber bushes should be used on the supports. They are quite fragile. Speak to Jim Oven.
