Tailshaft bearing for T5
Posted: Tue Feb 24, 2015 2:06 pm
I have just spent a depressing morning under my Tiger. Quite a lot of fluid escaping past the tailshaft oil seal of the T5. Can't seem to find a supplier for a new one anywhere. Anyone got any ideas ?
Also, the clutch slave cylinder is weeping. Unfortunately it doesn't seem to be a standard setup. Instead of the standard arrangement with the cylinder mounting to a bracket fixed between the bellhousing and the gearbox. This slave cylinder has a side mounting onto the side flange of the gearbox. I don't particularly want to have to split the box and bellhousing to insert a new bracket. Easiest would be to replace the slave, as it works fine. It is marked Aisin 13/16 on the casing, and when I did a search that comes up as a Toyota !!
Help please !! Isn't Tiger ownership brilliant
