Radiator
Posted: Wed May 03, 2017 9:09 pm
by s2mpf
Who makes the most efficient (biggest) radiator? I have alloy rad but still running at 95 deg C
Posted: Fri May 05, 2017 3:41 pm
That should work ok. I'd check thermostat. or water pump. Also sender can read wrong. Try infra red temp probe to double check.
Posted: Fri May 05, 2017 4:03 pm
by tigertim
If you still have the original. Get it re cored with 143 cores up from the original 90 can't get mine hot.
