Lots of bits needed after engine fire
Post by Brad1380 » Mon Jan 02, 2012 6:46 pm
Has anyone got:
1. Chrome side strips
2. 260 badge
3. Sunbeam letters
4. Wooden dash
5. Wiring looms
6. False floors
7. S/S exhaust
8. Carpet set.
9. Electric fuel pump.
10. Radiator shroud
plus all the other rubber bits that melt in a fire.
cheers
Brad
bernd_st
Post by bernd_st » Fri Jan 06, 2012 5:50 pm
almost everything listed here except the shroud and the false floors can be bought new from the relevant spares dealers. Would recommend you to try Brian at first. Furthermore the original fuel pump is a pain the neck. Try to get a new alternative w/o contacts otherwise probability is very high that you´ll have a lot of troubles...
Post by michael-king » Sat Jan 07, 2012 2:38 am
Brad,
Rick at SS lists repro shrouds, Randy Willet in the states sells false floors (but LHD) as bernd mentioned all the other bits are available from the usual suppliers in the UK and States.
tigerguy2
Fuel Pump Comments
Post by tigerguy2 » Sat Jan 07, 2012 4:15 am
Just like to expand on Bernd's point about SU fuel pumps. I had the version that had been converted to electronic switching versus the contact point mechanism. Lasted me about 20 years.
Unfortunately it starting dying on me when I was in the middle of the State of Georgia (USA) on a trip from Chicago to Tampa, Florida in the middle of our summer a couple of years ago. Managed to limp last 600 miles into destination in the cool of night with frequent stops.
A fellow tiger owner in Florida had an interesting perspective. He prefers the old point type mechanism. As he pointed out, the electronic system is great until it fails, then you are totally out of luck. With the mechanical system, you can open the "battery" door, remove the pump end cover, replace and gap the points and be on your way again. So in some respects, there could be some advantages to the mechanical, points type mechanism, depending on your circumstances.
It was during all of this that I learned the fittings for the SU fuel pump and the fuel line are a British pipe thread or something like that that is not readily found over here in the US. (Same situation as for the fuel line to cross over pipe at the tanks.) Also there seem to be some unique sealing washers that were not with my replacement SU pump. Managed to re-use the old ones fortunately. Fortunately, the pump was never replaced with a non- SU pump so I had the correct fittings on my lines. If your pump is not an original, hope you still have the old fittings and washers if you want to go back to a SU.
Sorry if I am the last one to have learned all of this. Certainly less likely to be a problem for you chaps in the UK! I am just passing my experience along as an abundance of caution in case it is useful to anyone else.
Gene
Post by Brad1380 » Sat Jan 07, 2012 12:24 pm
Thanks Chaps,
looks like i'll be drawing up a fairly large shopping list,
cheers
Brad
Post by martin172 » Sat Jan 07, 2012 12:31 pm
Brian sells shrouds and you can create a Tiger false floor from an Alpine one. It would ofcourse deprive the World of an Alpine spare.
bernd_st
Post by bernd_st » Sat Jan 07, 2012 2:57 pm
seemingly this turns into an interesting discussion. Certainly not the right place here but anyhow perhaps somebody may considerto move it to the proper chapter.
The fuel pump thing can be discussed forever. Of course replacing the good old SU with something modern can backfire. It always depends of what you install. It´s a similar discussion as with the electronic ignitions and in some cases the aftermarket quality is worse than the original parts...
Regarding the false floor: Never fitting them but what´s the actual difference ? Would expect the Tiger one´s to be slimmer...
Post by bigbob » Mon Jan 09, 2012 12:00 pm
Excuse my ignorance, but whats a false floor & where does it go? Is it the timber one in the boot. I'm worried now that my car might not be original.
H, Sunny 65
Post by H, Sunny 65 » Mon Jan 09, 2012 10:45 pm
It's like a floor, only different, and it goes, well, on the floor. :lol:
Happy Tigering
Post by michael-king » Tue Jan 10, 2012 1:21 am
bigbob wrote:Excuse my ignorance, but whats a false floor & where does it go? Is it the timber one in the boot. I'm worried now that my car might not be original.
The false floor is also reffered to as the toe board. Its the panel fitted to the passengers side of an alpine or tiger that the passenger puts their feet on. Gives a nice flat surface to make the floor mats easier to. They came into production on the S3 alpines onwards.
Post by bigbob » Tue Jan 10, 2012 11:18 am
Thanks for that, mystery solved. I had a footrest/toeboard once, but it rusted away a while ago. Thought there must be something else I was missing.
Post by martin172 » Tue Jan 10, 2012 11:25 am
They are there for your passenger to use as a brake pedal.
TXJ7
Post by TXJ7 » Wed Feb 15, 2012 8:47 pm
Brad, are you still looking for a carpet set? I have one in storage but it's not new and need to check out the condiition. If interested I'll dig it out and take some photos
Tiger Mk1 (289)
Jag 3.4 Mk2 (rusty!)
Cortina Mk1 Estate (302)
Post by Brad1380 » Fri Mar 09, 2012 7:40 pm
TXJ7 wrote:Brad, are you still looking for a carpet set? I have one in storage but it's not new and need to check out the condiition. If interested I'll dig it out and take some photos
Thanks for the offer, but i'll go with a new set as they are not too dear.
cheers
Brad
Re: Lots of bits needed after engine fire
Post by Brad1380 » Fri Mar 09, 2012 7:43 pm
Brad1380 wrote:Has anyone got:
2. 260 badge
3. Sunbeam letters
4. Wooden dash
5. Wiring looms
6. False floors
7. S/S exhaust
8. Carpet set.
10. Radiator shroud
cheers
Brad
Thanks for the info gents,
should also add
11. Holley, probably ebay one.
12. Tiger air cleaner.
13. Tiger rocker covers.
14. Some better wheels, be nice to get away from Minilites.
