Hillman Husky export front springs ***FOUND***
Wanted : Hillman Husky export front springs
Higher rated springs and are an exact fit for the Tiger. Perhaps considered more heavy duty for more demanding foreign 'climes' but I believe also that some of the works prep'd Tigers had them fitted also for competition - am sure somebody will chime in with a more accurate brief.
Rob, did you find actual Husky Export springs - they must be rare now...
Husky springs
Tony, no. I got HD ones from Brian. I remember on my first Tiger I managed to get Husky front and rear, the rears have 8 leafs.
Rob
Rob
I am pretty sure the stock front springs are different between the Alpine and Tiger. Would make sense with the different engine weights. I believe they are colour coded with a paint dab on the top coil although you cannot see the paint without taking the spring out.
I still have the original springs and they have a green dab at the top, which was shielded from the weather by the rubber "donut" atop them in the spring tower. I seem to recall reading somewhere that Alpine springs had an orange dab.
I just had a look at the old springs to confirm the color. There is also a stamping of some sort on the top coil that I cannot really read. It looks like an "O.W." followed by three numbers that are only half stamped with the top missing.
I am not sure what were the original spring rates. I replaced mine with some 450 pound springs from Dale A about 20 years ago. I am sure they have softened a bit since then, but still nice and firm without being harsh. Conventional wisdom at the time was that 450 was about as hard as you want to go for a street driven car.
Gene
Gene
