Panasport center cap Tiger's head project
Posted: Thu Nov 04, 2010 3:41 am
Hello all,
After completion of the LAT 9 center cap project. I have enough intrest in doing a Panasport insert of the LAT 9 Tigers head. It will be CNC machined out of aluminum and should be about 3/16" thick and 2" in diameter. I plan to remove the plastic Panasport emblem and glue/epxoy the insert to the cap. The cost will be $23 ea and shipping should be $15 for4 or 5. Contact me off list for pictures and if you want to order some. I will need a minimum of 30 to have the machinist make the run.
I have not had any complaints on the LAT 9 caps workmanship so the quality is not an issue.
Dave Green
alpdavegre@msn.com
Dave Green
alpdavegre@msn.com
