Right, I have a unilite dizzy , unilite ballast resistor and a unilite coil. So why is the coil failing ? Wiring is ok. Any suggestions?
Thanks Rob
Failing coil
Hi Rob,
How old is the coil? It sounds like it has developed an internal fault. You could try replacing the ballast resistor or re-terminate the connections to the resistor. Is it the correct coil for a ballast style ignition system?
Failing coil
Hi, coil is less than 2 years old,probably only covered 4000 miles.
