rev counter
rev counter
Hi i seam to have a bit of a rev counter problem it seems to be showing higher revs then it is, a quick blip on the throttle and it gos way off the clock,are they adjustable any help please joys of a new tiger,
Hi I had similar probs with my rev counter, check the earth connection on the rev counter mine was better once cleaned but it still had a tendacy to bounce between shifts.
I have since given up with the original unit and fitted a smiths electronic tach which I am very pleased with. The one I have is from the Cobra range . the smiths classic range is more similar to the original apart from a white needle, I think smiths may be able to put in an orange needle if asked.
Jason
Jason
My rev counter is not working yet. The electrician didn't connect it up once we had the engine running. I can't remember if he said it would not work or not read accurately because the ignition is electronic and the tac is set up for a points ign. But it could be changed.
We have people who specialize in instrument repair here, you must over there as well.
