first I want to say hello to everybody in the forum. Here is a short description of myself: I am 33 years old, married, father of a 2 year old daughter and I am coming from Luxemburg. Actually I am a proud owner of a Sunbeam Tiger MK1 B9472371 LRX FE and an Austin Healey 100/6 BN4.
I bought the Tiger 1 month ago and it is not running as it should be. As you can imagine, I have some questions and that is why I am hoping you can help me.
Originality is not so important, as I want to have an all-day driver-car and the car has to be reliable.
Brake upgrade:
Front:
Both front brake calipers are leaking brake fluid. I surfed on the net and I found an upgrade in the States from Wilwood that can fit the front brakes. Is this a could solution or are there better ones? I read here in the forum that somebody uses Brembo calipers and Peugeot discs, do they fit immediately or is there a lot of work to make them fit.
Rear:
I wanted to upgrade the rear brakes too on disc brakes. I got this on the Austin Healey and I would never get the car back to drums. I found on the website from Dale's restoration an upgrade for the rear brakes: http://www.dalesresto.com/parts.html
I hope this kind of links are allowed. On this website you can see the Wilwood front upgrade too.
Do you know alternatives or where I could get this parts in Europe?
When I change to this disc brakes, do I have to change the brake master cylinder too, or will it be big enough?
Carburetor and manifold:
The carburetor seems to be an original one, but it is not working well. I wanted to change it for a Holley or a Edelbrock.
Which one would you recommend and shall I change the manifold too, and which one to take.
Actually the car seems to have no real punch as the carburetor is not doing what it should do → give the engine life.
Wheels and rims:
Actually Minilite 5,5x 15” are fitted with 195/50 tires on both axles. The front wheels are scrubbing in the inside and as you can see on the pictures the front is too low, I will change the springs and the shocks as well. Which rims would you suggest and which ET?
Radio console:
Actually the car has no radio console but I wanted to fit a radio in the car. I surfed in the net, but I could not find one, where could I find one.
Cooling:
For the cooling I wanted to fit a Kenlowe fan and improve the air flow with some flaps in the front. Does the fiberglass-bonnet with air-hole bring a great improvement? If yes, where can I get one in Europe?
I wanted also to fit an oil cooler on the car, what do you think of this improvement.
That is all for the moment, but I think more questions will come when the car is getting in parts.
Thanks in advance for your precious help
Adrian
