Since the car has the boot floor and rear seat out to replace the chassis rails, the panel beater asked if I ever wanted to install a roll bar or bars.
It is a good opportunity to weld in some plates to the chassis to accommodate the bar. I thought I would ask those that have roll bars how they are mounted and if they had any good pics. I think the install of the bars will have to happen at a later date, but if the mounts are there we are half way there.
Roll bar mounts
Its Ok Rob, i understood that he was talking about welding in bracing plates, what i was offering was that its it better to bolt the actual hoop in rather that weld them.. the way they are supplied you can install them either way.gtsmrt wrote:Michael... I think you will find that Mal was not going to weld the roll bar into position, rather to weld strengthening plates in before the body is painted.
Even if you were welding the hoop in it would be advisable to brace the underside especially if you use the rear deck as the plates on the underside can be tacked to the vertical surfaces on the rails. In the event of rolling they are going to take quite a bit of lateral and compressive force.
As a side note Mal, the bar as installed in my car in theory are sold as "street bars" or "show bars" for legal reasons. the ones they sell as competition setups have a brace that comes forward into the passenger compartment floor.. good in an accident.. but not so good for street use.. though i have seen some with a removeable forward bar.
Another thing to consider is the odds of rolling vs being rear ended.. my head would likely make contact with the bar if i got hit from behind.. and that would be like being hit in the head with a baseball bat.. i have added foam to the area of my head.. but still something to consider.. as is making sure the hardtop and softtop can clear it. Finally.. how tall are you.. my head sits above the roll bar so my head is gogin to be the first point of contact.
