which promptly all came of their terminals before I had seen where any had come from. After trying to find the correct wire for the correct terminal ( any help here would be appreciated ,to make sure I have it right ) I no longer have a ign light come on , but I am getting 12v readings from both sides of the coil. Even with all the wires off the ign switch I am getting 12v at the coil which dosn't seem right to me
As you can probably tell I am no authority on wiring so any help would be appreciated.
Also the car has provision for two fuses which were removed. What amp should I use
Cheers Malcolm from NZ
