Have any of you guys converted your hubs to 5 stud application? I know you can buy front alloy hubs from Wilwood and Aerospace components but the rears are a little more tricky? Full replacement axle or new shafts?
Any advice will be very welcome.
Thanks for the link.V8 burble wrote:Ash,
If you keep the same PCD you can let a decent machinist modify your existing rear hubs to 5 stud.
I think that the Jaguars with that 4HA axle had 5 studs, but the PCD is probably different.
For a definitive answer contact:
http://www.gearboxman.co.uk/
Telephone: 01582 840008 (Speak to Bernie, the owner).
Graham,gvickery wrote:Michael
I hadn't heard of the goodies you mention being fitted to the Maurice Smith (Autocar Editor) MKII [His Tiger was a pre-production car based on MKIA B382001528 HRO] and today is in near standard spec. The production RHD MKII supplied to Gregor Grant (Autosport Editor) was almost certainly the standard item at first and remains pretty much so today.
