ksherlock
Post
by ksherlock » Mon Jun 24, 2013 2:30 pm
Could someone tell me how many bolts should attatch the front part of a Tiger boot lid hinge to the body., I can only feel one on each hinge when reaching in from the boot.
Post
by meadowhog » Mon Jun 24, 2013 9:18 pm
Just the one.
Post
by martin172 » Mon Jun 24, 2013 11:05 pm
meadowhog wrote:Just the one.
I'll second that.
redbaron
Post
by redbaron » Mon Jun 24, 2013 11:14 pm
The boot lid hinge is held onto the body by a 1/4unf threaded stud,use a stud rather than a set screw as you will not strip out the softer threads in the cast hinge when fitting.
alpine5gt
Post
by alpine5gt » Tue Jun 25, 2013 8:16 am
And don't use the replacement rubber hinge gaskets, they slip and you will damage the paint very quickly. Replace them with cork and no slip.
Post
by garyv8tiger » Thu Jun 27, 2013 7:11 am
simon at sunbeam supreme has the correct wax covered paper gaskets much better than the rubber ones
Post
by Tomaselli » Fri Jun 28, 2013 3:46 pm
useful tip, didn't know about paper gaskets
bernd_st
Post
by bernd_st » Fri Jun 28, 2013 6:12 pm
Still prefer Rick's rubber ones. They are self-adhesive on the underside and will never move once installed...
alpine5gt
Post
by alpine5gt » Sat Jun 29, 2013 6:47 am
bernd_st wrote:Still prefer Rick's rubber ones. They are self-adhesive on the underside and will never move once installed...
Sorry, newer ones maybe, mine did move, result a big paint chip.
Post
by meadowhog » Sat Jun 29, 2013 9:30 am
Mine have moved, with usual mess. They are a type of vinyl. Is there a best solution?
alpine5gt
Post
by alpine5gt » Sat Jun 29, 2013 9:47 am
I think a previous post about waxed paper may be good, others say a thin cork gasket will also stop the dreaded slip.
Post
by garyv8tiger » Sat Jun 29, 2013 12:49 pm
rubber ones are useless .originals are waxed covered paper
Post
by meadowhog » Sat Jun 29, 2013 1:07 pm
I remember an Alpine that won the wooden spoon award back in the 80's. It had 6" nails holding it together.
Post
by garyv8tiger » Sat Jun 29, 2013 10:09 pm
meadowhog wrote:I remember an Alpine that won the wooden spoon award back in the 80's. It had 6" nails holding it together.
tomasellies tiger is like that
